My 98 model Seadoo xp limited has been out of use for about 9 months. I just got it out of the garage the other day to charge the battery etc ready to hit the water but the throttle cable seems to be stuck and unable to squeeze in. I sprayed some lubricant down the cable line in hope of movement but nothing. A mechanic said the problem is most likely some corrosion in the carburetor from salt water so it will need to be cleaned out etc. (His advice is very limited without hundreds of $$ coming out of my pocket). My problem is getting to the carburetor now.. its almost impossible with the exhaust system over the top of it and im hesitant to move this if its not the best way to access the carburetor. Can some 1 please help me with some wisdom and mechanical know how??
Thanks,
Ash
Thanks,
Ash
