98 xp does nothing
shaun oconnell
i have a 98 xp limited. The vts motor fried and blew the fuse. I replaced the fuse and the vts and now nothing works. Not even a beep when i put the key in. Please help it ran great prior to this
Check battery?
Have you checked the battery and all the connections? If your not getting any power to the gages or any accessories, no beeps when you put the lanyard on, then you've likely got a loose wire connection somewhere.
Push the start/stop button 5 times. This is for the advanced diagnostics. You should hear a short and long beep. If you don't, then you got a loose wire somewhere...........:cheers:
