So had too the boat off the trailer and started both engines. I let it idle and warm up for a few mins and then went up and down the pond a few times. I then went ashore to pick up the wife and kids. Jumped in and started up the port engine...starboard attempted but but wouldn't go. Then the starter would stay keep turning off until I turned off the main switch. Flick on the main and it would already start trying to turn over. I'm guessing bad solenoid but took it off and cleaned it up (ordering a new one). It started right up after in the driveway.
So few days later I went back out on the pond and tried the starboard engine..It fired up. But nothing out of the port. When I had the starboard going and pressed the starter for the port it would shutoff the star and get a long beep. I'm thinking the battery is getting weak. I only got this boat last fall and not sure the age of the battery. It's a Napa CCA 550 amp sound about right? I'm going to put it on charge and then bring down to napa for load test.
I also have an extra 100 AHr deep cycle battery from a solar job. I was thinking about doing the two battery mod and use this battery for stereo. Any issues with having a starting battery and deep cycle? The 1/2/all switch, Do you have the starting battery on 2 and then once both are running flick it to all so that the deep cycle is charged? Or do you just use the deep cycle when you are engines off and then went you get hoe put the deep cycle on charge?
