I just acquired this boat and decided to pull the pumps to see how the wear rings and impellers were. I have the port pump off and removed the impeller. Looks like i have to replace the impeller and wear ring.
I'm having trouble removing the starboard. is there a hose attached from inside the boat that i have to unclamp? I can pull it about an inch but that's it. Only thing I can think is that the impeller is seized to the shaft and the inch is the shaft play in the boot. I guess I'll have to remove the clamps and pull the pump and shaft out?
Click image for larger version.
Is the heavily corroded bit the seal?
