Dr. Honda, thanks for all your help.
To answer your questions...
a-c) When I rebuilt the carbs, I did not replace any parts. I only replaced gaskets, diaphragm, o rings , and pop off springs. I don't know the brand of the kits, bought them from a local supplier and they had generic packaging.
This is most likely our issue. AND... looking at the picture below... that is not an OEM diaphragm.
d) If by pump parts, you mean fuel pumps, I don't have these. My pumps are separate from the carbs.
You may have still rebuilt them, and they are very similar as the internal pumps.
e) By high speed check valve, I am thinking you are talking about the little clear plastic flap above the pilot jet. I replaced these and they appear flush.
Yes. If it's flush... it's fine.
f-g) To be quite honest as I am new to this, I am not sure what the bypass ports are. Are you talking about the return fuel ports?
The bypass ports are the very tiny ports that are exposed as the butterflies open.
h) I did change the springs and I have a pressure tester. I've even tried a lighter spring at the suggestion of one of my local jet ski mechanics. That made no difference.
You need OEM. Pop-off only works when you have OEM parts, in the correct size.
i) Needle arms are flush.
ok
j) Problem is prevalent with or without airbox and with or without screen. No noticeable difference either way.
k) I did check needle valves wet and they hold pressure without leaking.
l) O rings were replaced on both needles.
m) Needles were adjusted to factory spec. 0 turns on high and one and a half on low. I have tried making adjustments to both and this makes no difference to problem.
n) I have just checked carb jets low are 67.5 and high are 142.5 mag and 145 pto which is all factory size.
1. I will recheck the check valves.
2. The airboxes are oem.
3.I'm starting to think this may be the made in china rebuild kits. The diaphragms do not have the red pins like the Mikuni, they instead have a round metal tab. This could possibly be keeping the needle valves from opening far enough and not letting enough fuel in. I went ahead and purchased the real Mikuni rebuild kits this morning. They are obviously not nearly as cheap as the other ones I bought, but the extra money would have been well spent before if that's what this is. Here is a pic of the diaphragm.
