sandshark
Hi, just introduced myself in the intro forum. Now a couple questions:
I very recently picked up a 98 speedster.
Cosmetically some sun damage but that part is coming along nicely with some elbow grease and TLC. There is unfortunately no storage tray for the engine compartment, nor can I seem to locate one. (Help?)
Three items so far:
Due to what I feel is a summer in saltwater on Coronado, there was some pretty good corrosion on the steering nozzles and a lot of the paint was eaten away. I have removed them and salt-x'd, wire wheeled, and dremel sanded to good metal, and will recoat them this weekend. I'm going to use Rustoleum industrial gloss black. Any issues?
Steering was VERY tight. A dealership said I needed a whole new cable and was willing to do the install for 500 bucks
My thought was saltwater corrosion @ the transom. I basically took apart everything from the thru-hull fittings at the transom on back and cleaned, polished, and lubed all pieces. Steering is (without anything to measure against as far as other boats) 95% better. Again, any comments?
Now my bigger question: The boat apparently had a full service last summer, and the 787's look pretty clean. Some very mild smell of fuel in the engine compartment which I wil assume is normal? New Battery, Plugs, etc. The engines sadly were not prepped for storage and I am looking at 6 month old gas w/out stabilizer. The engines both start great, out of water idle is @ ±3500 rpm. (Starboard Tach is sticking a little though, and I apparently am not alone in having my gas gauge not working) As soon as I bump the throttles, they (equally, although I run only one at a time so I can listen better) stagger and hiccup. No revs. Fair amount of smoke. I was told 300-400 for full carb rebuilds by (again) a dealership. My thought is they have maybe some varnish or just need cleaned out., etc. Comment?
EDIT: I was just reading something about rev limiters on a thread in here somewhere. I want to now add that this is in Neutral. I am hooking water to the lower pump support flushing connector as I test each engine. How long can I run for when connected this way?
All in all the boat is pretty clean and I am looking forward to getting it on the water. The price (from a good friend with way too many toys) was VERY tempting so I jumped on it.
Thanks and again I appreciate you all being here.
-M.
Three items so far:
-M.
