KYmayfield
Quick recap, last year both engines were extremely hard to start,would die randomly and i was barely able to get it home (i live on the KY river) So i decided to rebuild the carbs,and rave valves.
Port engine started right up on the first push, starboard negative. It would crank and or start to fire but never stay going. Pulled those carbs 2 times to double check i rebuilt them correctly and they were all good. At this point it seemed like it wasn't getting fuel, starter fluid would have it go for a second or two then die. Replaced the fuel pump and nothing changed, new spark plugs still nothing. Tested Spark and it was good, battery is good bc i can start the port engine. The needles are set exactly the same on the port and starboard engines. Compression on the engine is 140, adding an extra ground to the engine didn't help either. I also made sure the engine is pulling fuel.
Maybe a fuel line is collapsing but they are big lines? Any Ideas or suggestions on what to check? Help please
