98 rave valve check valve
Dtrain55!
getting ready for water finally. Should it be easy or extremly hard to suck air through the rave valve check valve ? Thanks ?
I had the same question. I won't hold my breath on an answer. Going to google .
Try them with a Mity Vac
3 psi will make your eyes bug out..and your ears pop
I think fuel tanks vent at 3-4 psi
most 1 way checks you can blow 1 way, (some times easily) not the other
You can suck on it and get air easier than blowing for sure. Put a napkin over the tube. LOL The biggest problem is if the valve is not holding. Blow into it and if it holds you're good.
