Hey wheeler. Welcome to the forum!
I would start with a compression test (easiest test first). You should around 130 to 150 on each cylinder and they should be with in 10% of each other.
If all is good there you can go into more detailed troubleshooting and start with the fuel system. Check the fuel lines to see if they are gray, if they are, replace them with black fuel lines from an auto parts store.
Then go through the carbs and all filters making sure nothing is clogged.
Hope that gets you started.
Ryan
