So I finally got out in the garage and tore apart the pwc and got the engine unlocked...I took it out and ran it with premix 40:1 and it ran fine...a little boggy but a lot longer than 5 minutes...this time it went for about 1.5 hours...then it just started bogging out and finally died. I did a compression check the front cylinder is at 150psi the rear is sittting at 40psi...oops
I took the head off again and the cylinder doesnt seem to be scored to bad and there is a slight presence of oil/fuel going by the rear cylinders oring/head gasket...could it be I just need a new set or orings/head gaskets? Possibly a warpped head or do I need to jump into rings and a hone for the cylinders? Anymore help would be greatly appreciated, thanks for your last responses!
