Idiotwita elec prob
I have been working on this 98 gtx limited since Christmas I had to replace the motor as it was seized and no hope of repairing it. Got the new motor in got a battery and wouldn’t turn on turns out just a fuse. Replaced fuse tried to start it turns over stops turns over stops all holding the button firm replaced solenoid and did the same thing checked wires all fine checked starter all fine checked start stop button all fine tested wires for power drops or just 12v’s wire to the button is 10 11v wire to the solenoid bounces all over so no idea. But that’s not the major thing I can get it started and keep it running and idles fine but on the dash it says it idles at 3k rpm but it’s definitely not and took it out to the lake today and went to give it some throttle and it won’t go past 10 15 mph and wont get on plane and it also thinks it’s at 8k rpm when it’s 100% not at that high of rpm and it sounds like it’s rev limiting but not really. First thought is plugs or clean carbs but I find that hard to believe it would cause it to think it’s at 3k rpm on idle.
