bohnsorge
Hi Guys,
first of all I would like to say hello to everyone and thank you for any kind of help (and sorry for my bad English).
Moving on, I have a Sea-Doo GTX Limited 951 (on carburetors) `98 and I have a engine idle problem (I looked at threads in this forum, but did't find a match for my problem). Please take a look at the video, I think it will illustrate the problem better than I will describe.
Previously, these symptoms were at higher rpm (but engine doesn't go out). It turned out, that I had a damaged carbon ring on the shaft and damaged bellow in the water pressure regulator (water got into the hull).
The repair consisted of replacing the ring and repairing the regulator (bellow change), I also cleaned the exhaust valves, decided to replace the spark plugs with new ones and check the compression, which I think is ok, 125psi on both cylinders. After these treatments, I took my PWC for tests. It starts without any problems (both on a cold and hot engine), after the first 15 minutes of sailing, everything worked properly, so I continued my test (both slowly and at wot) for a total of 40 minutes. After those 40 minutes there was a problem like in the movie. Although this idle problem, my GTX accelerates correctly, and when I hold the throttle gently and hold 1500 rpm, nothing is happening either, the engine does not wave or go out.
Do you have any idea what might be wrong and what should I check / fix? I will be grateful for any hints / suggestions.
Regards
Borys
Regards
Borys
