Hello to all !! New member and just bought a 98 GS 717. I ran a compression test before I bought it and knew it was low, right around 88-90 on both cylinders. Previous owner started it up for me and it ran OK, could tell it at least needed the carb rebuilt, that's not to hard so I bought it because I enjoy a project. I'm pretty experienced with mechanics, nothing professional though, and this engine is new to me so I need the communities experience. I was rebuilding the carb I noticed the oil pump cable wasn't hooked up right, might as well not been there, I need to get that straight, so haven't tried it on the water yet. I replaced all of the Tempo fuel lines except vents. Cleaned screw on fuel filter, added additional inline fuel filter. New spark plugs and some general cleaning. I checked the compression with two different testers, one is old and the other just bought new from HF. Unfortunately I don't have proof that either are good other than they read the same.. End Background ..
It runs great after the carb rebuild (out of the water on the hose). How bad is 90 pounds in both cylinders on these engines ?
Usually if all cylinders are low, it is either just an old engine or there is something common to both cylinders causing it. What are some of the common reasons anyone has seen with these readings? I can name a bunch of generic reasons, but you all are experienced with these particular engines.
Thanks in advance for anyones help and suggestions.
