Howdy
Pick up a 97 XP (one of those Yellow things) for free.
It was under water for two day's, then sat for a few months.
Motor was pulled and it was totaly rusted and could not rotate crank (normal).
Installed recon motor, but have No electerical per say.
When the lanyard is connected it beeps once only.
The MPEM is located up front with engine and the Battery fuse has no power and the Acc fuse keep blowing.
The only way the Acc fuse dose not blow is when the Mag housing is removed from the engine.
Is the wire diagram the same for XP limited I have several manuals but can not fined one for this ski, All the MPEMs are located in the rear
