adamcharmaine
Hi Guys,
I have recently purchased a 97 XP. Rebuild 4 hrs ago. Told the valves with the red caps at the top are new but one seems to have melted the plastic cap. I have screwed the cap back in and the ski runs great when under power. Problem is that the engine seems to want to stall when no throttle applied and takes a couple of pumps on the throttle to keep running. I am pre mixing fuel as it has been converted to run a sump style oil tank where the original oil tank is. Should these things idle with no throttle then pull cleanly? or am I expecting too much? Any ideas on a fix?
