Traitor5150
Ok Just got my 97 xp running again rebuilt the motor crank pistons counterbalencer etc... Also rebuilt the carbs i put the hi and low speed setting to where they where last year before the crank blew. when i fired it up out of the water ran great put it in the water it runs great except it does not have full power mabey tops put around 35?? feels like no power band then i hit a wave and bam it takes off plenty of power if i let the throttle off below half does the same thing wont go over 35 unless i hit a wave or play with the ski a little to get the pump to grab a little air. This seems like a carb issue to me. Second problem is rave valves are leaking oil i dident replace the beolows but they arent leaking there they are leaking from the houseing gasket havent taken that apart yet but why would those be leaking new seals all surfaces where clean and flat just seems odd
