97 Xp Please Help!
ffjsh
Alright i have a 97 seadoo xp and im begining to have problems with it. It seems to be fouling plugs alot. It will run perfect for a little while and then if im not always on the gas going fast the next time i go to crack the throttle it boggs out and runs like crap..... The other day i took it out it ran fine. my friend had never been on a jet ski before so i let him ride it and he had a lot of trouble getting on it in the water. The jet ski really rolled all over the place. it never rolled completely over but it came dam close. I got back on it and it ran horrible. It would idle but wouldnt rev up.....I was reading about the oil injection and maybe thats the issue....idk im thinking the oil, im thinking the carbs might have junk in them, im thinking it might have taken on some water.....IDK i need help with this cause its driving me nuts..... Thanks for anyones help.
Sounds like your on the right track. Start with a compression test on the engine. If both cyclinders are the same and over 100 psi your good there. Clean the carbs and replace the fuel lines if they are the gray ones. Those gray ones are crap and will leave a mess in the carbs and also get clogged. Also check to make sure your oil pump disk in set on the alignment mark.
Is it hard to clean the carbs?? can anyone tell me how to block off the oil injection and what should my premix be??
I would leave the injector intact. It is a variable rate injector meaning it injects oil at a different rate depending on the rpm's of the engine. It uses less oil and is less prone to foul plugs. It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. If you have gray fuel lines you need to replace them with black fuel lines available from auto parts stores like Auto Zone. Measure the length you need and bring a sample with you so you get the correct size. Replace one at a time so you don’t get them mixed up. If you need clamps replace them too. Use small stainless steel clamps also from the auto parts store.
Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
yes i have the shop manual. i will leave the oil injection alone. it works fine....knock on wood....im gonna clean the carbs and replace the gray lines, the plugs and the fuel filter and see how she works. thanks for the help
