97 Xp Moody Starting
Giangi
Hope somebody can help
The ski starts inmediately the first time. As we used it suddenly does not want to start. Check spak plugs and they are dry, definatly no gas going into carbs. Next day it will start perfect after we move the gas switch to on.
Last time while running it started smoke a lot and it would not accelerate at all put the fuel in reserve and inmediately started running normal. The gas tank was 3/4 full.
I bought the ski used and I noticed that in the engine compartment had a manual pump same as the ones used in the outboard engines. As I never saw one in this type of ski I removed it long time agoand the ski was running OK. Does that pump is used to prssurized the tank? Is that the problem? All fuel line replaced with black ones except the breathing hose that goes to the tank.
Please some help will be highly appreciated
Giangi
Thank you Timmyboy. I will do that even if I cleaned the selectos valve3 months ago.
What about the manual pump, shall I put it back again
