Hey guys, new poster and jet ski owner here. I have been around them since i was 13 just never owned one. Rode my friends instead. BUt now i have finally gotten my own.
OK the story is i just picked the ski up a few days ago. I knew it was a bit of a project when i bought it. So I took it out yesterday to see if i could get it running after it had been sitting since last summer. Easier said than done. It would start every once in a while but wouldn't stay running very long. ended up killing the battery a few times trying it. I was figuring this would happen because i know how 2 strokes and carbs are when sitting for a while. I eventually got the carbs all cleaned out this morning when the electrical problems came around.
When i was out on the water I could tell the key was being finiky. It wouldnt always recognize it and some times i woud get the one long beep others i would get the double....but i was able to work around it. The times it was running sometimes it would cut off like i pulled the key when i really did not. It also shut down when i pressed the VTS button once when i was doing full throttle. I went out this morning to work on it some more and i got it running and it actually sounded good.....like i said i think i got the carbs all cleaned out with fuel treatment and such. I decided i should get it to a hose so i cvould run it longer than a couple min. I took it across my apartment complex to where the hose is and when i got there i could only get it to try and turn over like once.....the rest of the time it acted like there was no key plugged in at all. I checked the ground and some of the connections and cleaned them and made sure they were all good and still nothing. I did some reading and i disconnected the VTS fuse and checked the 5 amp MPEM fuse and it was fine. I did the self diagnostic mode and when i got to the part where i needed to listen for the beeps i got nothing.
I am thinking somewhere there is some bad wiring to the key post. WHat do you guys think.
Thanks
Thanks
