So here's the scoop with my VTS. When I bought it, it didn't work and since I've been working on it today (carbs and the fuel sending unit/plastic "welding" fix) I worked on the VTS. I noticed the fuse was blown so I replaced it. Then I removed the motor and it was full of water and was locked up, so I thought that must be the problem. I got the motor off the gear set and rebuilt it and hot-wired it to my tractor battery and it works fantastic. So I lube everything up, reinstall and it doesn't work and immediately blows the fuse......so I remove the motor again to make sure it still works alone and it does. I reinstall it, new fuse and nothing, so I put a 25A in for a quick test and I see smoke--scary but I think from the VTS module.....is it possible that theres a dead short in it?
I didn't remove it but it doesn't appear to be serviceable--any clue whats in it? As a practical matter, assuming I fix it, how much does it help the ski ride/plane out, etc. Right now I just have it set with the gauge up and will try to run it tomorrow.
Any idea how much a VTS module costs?
thanks for any help--this thing had lots of problems but I think it should scoot along tomorrow!!!
