I am working on a 97 spx and the starter is pulsing. In other words if you hold the starter button down it will turn over for a few seconds, then stop, then turn over again for a few seconds. I thought it was a bad starter at first tested starter and it works fine...then i thought it might be a bad solinoid so i tried a brand new one and a used one i have in shop..still not it...switchs are good and the starter drive is good...and its deffinitly not the crank partially siezing b/c i just put a brand new hot rod crank in it along with new wsm pistons....I am thinking it is The MPEN any suggestions? any advice or comment are greatly appreciated
Thanks
Matt
Thanks
Matt
