Pwnage1337
Hi all
I have a 97 SPX that runs great. The issues i have with the ski are:
VTS doesn't work - haven't checked the motor to see if it will run with voltage applied.
The beeper does not work. I have replaced the beeper with a new unit, and tested it to 12 volts, and it lets out a nice screech so i know it works.
Gas gauge not functional.
I have pulled the grey box from the ski and checked all of the connections inside. they all appear to be nice and tight, i checked resistance through the wiring harness and get about .2 ohms on the beeper circuit.
The MPEM is a Seadoo OEM.
Could i have another issue at hand, like poor ground that is causing none of the gauges to power up?
