sportster97
this is my second year with this boat and im still having the same issue, some days it works fine and some days it doesn't
its definetly a cavitation issue that im having, i have already changed the carbon ring, seal carrier, o rings, accordion boot , clamps, and wear ring, impeller is fine, what else can i try? i also get water in the hull, sometimes allot of water, sometimes next to no water,
could it be the engine is no longer aligned?
or since the boat is so old could the engine have moved to the point where theres not enough pressure between the carbon ring and seal carrier ?
anyone have a idea i can try
thanks
thanks
