97 Speedster Smoking (only 1 of 2 engines)
Greetings all,
Recent purchase of a '97 speedster has been a blast so far. Project boat that simply needs some TLC. I am looking for the forum opinion on only 1 engine smoking.
Here are the details:
* Port side engine smoking (blue) at low RPM's to the point where it nearly chokes itself to a stall. (NO PROBLEMS WITH STARBOARD ENGINE)
* Automatic Oil system still in place.
* Hesitates as RPM's increase to get the boat on plane, but then runs smooth once boat is past mid throttle to top end.
* New plugs in both engines which temporarily helped until 2nd start when engine again had excessive blue smoke.
I am not familiar with the automatic oil system. I do expect blue smoke from 2 cycle engines, but expect it to be consistent between the two engines. Is it possible to be mixing at different rates for both engines? Any other comments/ suggestions?
Greetings all,
