filthyoar
Was cleaning my boat today and decided to hook it up to a hose and run the engines a bit to flush some clean water through. When i hooked up the hose to my port engine and started it then turned on the water I noticed water spraying around from under the cyclinder head cover. At least I think that is what that part was called. Is there a gasket on the cover that may have gone bad? If so is it fairly easy to change out? What other problems could this signify?
If it is needed I can snap a couple photos of it tomorrow just to make sure that I am talking about the right part.
Once again I am struck by the curse of boat problems right when warm weather starts showing up .
