Hi, I'm new to this forum but hope I can get some help. I purchased a 97 seadoo xp a year ago and have had nothing but problems and I'm about to give up on jet skis if I can't get this fixed.
Everytime I take it out, it starts and runs relatively fine. After about an hour or so, it just shuts off and won't start. This is more annoying because it usually happens in the middle of the lake so I have to swim in. After sitting for about 4-5 hours it will start again.
Sometimes after it shuts off, it will try to turn over but won't start, and other times you hit the start button and nothing, sometimes you hit the start button and it make 1 beep and that is it.
I was able to test for spark one time after it shutdown and it had nothing. This leads me to believe it is the ignition coil or something with the magneto? I already changed the rectifier and new correct plugs/and gap. Battery is fine.
Other things that might help diagnoise.... when running it detenates at low rpm's. The spark plugs become oil fouled (prob from detenation) but I'm not sure why. I run 40:1 mix (no injection). Could the iginition timing be the problem? Also, it seems to have a lot less power that it did when I first got it.
Can someone please help? I'm tired of swimming accross the lake
