97 seadoo xp fuel line replacement
jtfarrill
I have a 97 xp that I am replacing the gray line some of the line is 8mm some of the line is 6mm can, I replace all with 1/4 line? I can get it to fit were the 8 millimeter came from but was worried that it would cause a fuel restriction should I use bigger line were the 8mm came from
Fits perfect were 6mm is?
Any help would.be appreciated someone surely has experienced this when replacing gray line
Thanks in advance!!
When I replaced mine, I used 1/4" for the 6mm line and 5/16" for the 8mm line. Just do one line at a time and replace it just as it was. Don't introduce what might be a problem.
btw, you're posting in the 2-stoke boat forum.
