seadooxp89
I have a 97 Seadoo XP . Engine brand new rebuilt. Rebuilt the carbs and had a problem with popoff pressure had to order original springs and fix that problem which I did. Now when I start the ski on the water right after Idle on the throttle the ski bogges out and wants to die and shut off but then if I give it a little more throttle it goes. I let the ski warm up and tryed at the same spot again a little bit over idle and it bogged down and wanted to stall out again. I tryed it several times and everytime it wanted to do the same thing bogged down and start to stall out. Might be a hesitation but I get nervous and give it a little more throttle and then it goes so I'm not sure. Would this be the ski running too lean or too rich? I have a feeling its the low speed screws but dont know if I should enrich the fuel or lean it out by turning the low speeed screw in or out. The Low speed are at 1 and 1/4 turned out because alot of people said to turn them out 1 1/2 but the book says 1 so I went in between. When the popoff pressure was too low it never did this and had no hesitation or bogged down at all but it was dumping extra fuel into the cylinders. Can someone help me ? Which way should I turn the low speed screws or is that not the problem?
Sorry I'm a beginner with jetski's and trying to learn. Thanks
