Hi,
New to forum but would appreciate any help. Seadoo runs ok for 5 minutes then bogs out. Checked compression and found 150lbs on one cylinder and 130lbs on mag cylinder. Also noticed cylinder head looks heated on mag side. The rave valve on mag side i found piston melted and spring broken. I know i will need to repair topend with kit but not sure if crank will also need to be looked at. Seadoo has 49 hours on engine and just wondering if there is a way of diagnosing a bad crank or can i get away with new cylinder and piston?
