97 seadoo voltage regulator
kreed
Anyone know where and how many voltage regulators are on a 97 speedster. I thought there may be more than one because it has two engines.
I would look in the elect box in motor compartment. Look for 1 in square w/ 2 yellows and 1 red wires from it, might have clear/yellow jelly look'n face to it
Ok, I'll check it out, I think mine blew out, batteries going dead and when the motor (I say motor cause that is all that is running now, one) is running the battery is still only reading 12 volts, not 14.
It could also be the stator. i have had one go bad on me and it sounded like a fairly common problem. you can check it by testing the resistance of the 3 yellow wires comming from the rectifier, disconnect first, If you get an open circut it is bad. An owners manual will help you diagnose the problem.
Here is an option if you need a seadoo repair manual. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and privet use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
