small explosive?
ok... seriously.........
The rear seat has bolts that you can get to from the engine bay. The armrests have bolts that you get to via the cup holders just in front of them. Those are a pain in the butt. My arm is too big. You need someone that isn't bothered by fiberglass and has skinny arms. (you need a 10mm socket and small ratchet)
The bow seats have body trees and they are generally sacrificed to get them off. the bottom just pull it up. the back rest has trees and pins. as I recall... you pull it forward from the bottom, and once the trees are out, lift it up. (the top has aluminum guild pins)
