Hey, been using the forums for a long time but have never posted. Hoping for some tips as I'm kind of stuck on what to do. Any opinion would be greatly appreciated. 97 Gtx good compression. Good fuel lines for a long time now. Use quicksilver pwc fully synthetic. Starts perfect idles perfect runs perfect. Tested rectifier had good voltage on battery at 5500rpm. Had a problem with my mpem so replaced it with a used one from parts dealer then it ran perfect.
Started to have a problem jumping over 5400 rpms. It gets there and no matter how long you hold the throttle won't jump up and slowly bogs down lower. I can feather the throttle until it jumps up and then will run forever at 6800rpm until I come to a stop and then goes back up to only 5400rpm.
So I cleaned my rave valves with new o-rings, gaskets, bellows. No luck on fixing problem. Water regulator showed stains from leaking so I took that apart cleaned and put back together with pipe dope on fitting no more leaks but still experiencing problems. Spent a long time on the water adjusting all three valves and testing but no luck.
The best I could get it to run is water reg. flush(there were 3 existing washers under the spring I left in it) - both rave valves screwed in all the way. Still takes a lot of feathering of throttle to jump over 5400rpm.
Do you think the springs on the rave valves are weak and need replacing?
Do you think adding a couple washers under the spring like the water regulator valve had on it would allow me to test for weak springs before ordering new ones?
Also valve pistons are the slotted kind and are clean now. But the chambers around them is very gunky. Should I try cleaning them? Concerns with this are dropping the deposits down into chamber, and also creating too much slop or wiggle room around the valve piston.
Thank you very much for any recommendations.
