TheCabralFamily
This weekend we purchased a 97 SeaDoo Challenger, and were very excited to take it out...the boat did not share our excitement..
Here's what I know so far
Purchased it on Friday, and when I looked it over both engines started right up (On Trailer) , although it took 2 new plugs in the right engine to fire up quickly However they both ran strong and clean. We trailered it about 90 minutes home.
Sunday morning, all set to go for a ride, replaced all 4 plugs with NGK BR8ES Plugs, fresh oil & Gas (Set to premix at 40:1), and dropped it in the water. Left engine fired up, but the right took awhile (5 mins). Once both engines were idling, I pulled away form the dock. Once out 30' the engines would not rev up past 3500 rpm, both were at the identical rpm speed and I had a large amount of smoke coming from the engine compartment. both engines would stall, and take awhile to get up again.
Called the seller who confirms he was out the following weekend in it, and it "Might be running too rich". I pulled back out and added a 5 gallons of additional gas (No Oil) and tried again with the exact same results. This time I over started it and took out the Left Stater (now on order). I'm hoping there's a simple solution to all this. Thank You
