'97 Sea Doo Speedster. exaust leak
hmmmmmmmmm?
Thats a hard one.....it's probably the rubber gasket on the through hull part. When the motor is off and the engine compartment is open, do you hear water running into the back of the boat? If so, that hull seal (rubber) is dry rotted. Because with the motor off, that flexible hose between the exhaust and the resonator shouldn't have any water in it........:cheers:
