I went and bought this not to long ago I bought a new agm battery with 325 cca and it will only crank over without plugs i tried just putting 1 spark plug in 1 out of the 2 pistons it cranked fine but when I swapped the spark plug that was in the first piston to the 2 piston it wouldn't crank it would only do 1 rotation like it had a dead battery. I took some of the top end off to look at the pistons the cylinder walls and piston look great. I'm wondering if the starter could be weak or maybe to much friction with the jet. when I get home I'm thinking on trying to jump the starter to see if the solenoid is weak. any advice would be nice
