I just recently purchased a used 97 gtx that had been sitting up for about 3 years. After a lot of tlc and cleaning, rebuilding the starter and replacing the battery , I finally got it running in the yard. I took it out on the river and it ran great. I kept it out for 2 - 3 hours, about 1 hour into the ride it died on me , like i pulled the lanyard out, even though I did not. So then it would not start untill a few minutes of (duh, what do I do now) I pulled out the lanyard and put it back and it started right up. No more problems that day. I took it out today , after charging the battery ,because it would not start in pre trip check , then it started fine in the yard and at the river. So off I go , I get a bout a mile away from the dock and it dies, so then I pul lanyard out ,put it back, it fires right up, for about 30 seconds , dies again, does this several more times , until I finally kill the weak battery and get stranded.
I get it back home and charge the battery and it fires right up. I ran it for about 10 seconds and cut it off because I did not have the hose out, then I hook the hose up fire it up , and by the time i turn the water on it dies again., and then again. I give up for tonight. Any ideas anyone....???
