97 GTX Water Flow Regulator
gsergio
I had a bad water leak from my water flow regulator so I took it apart and found a broken spring. I replaced the spring but it is still leaking. The leak is coming from a hole in the bottom of the pressure regulator hosing. Is this hole supposed to be there? How can I stop the leak?
How do you remove the special clamps that are attached to the water flow regulator and the plastic T that connects to the water line?
How do you remove the tie rap that connects the black line to the water flow regulator? Can I use the right size zip tie to re-attach it?
