chrisny454
The problem:
I will be riding along and the machine will just shutoff as if someone pulled out the safety key (but the key is still on the post). The behavior is random. Some days it will only happen 3 or 4 times other days it will happen every 10sec, 2 minutes or whenever. Totally unpredictable. I have two keys and it happens with both. The computer just totally shuts off, and I have to take the key off the post and re-insert it in order to get it to start again. (If I dont take the key off and try to start it, it will act like there is no key on it, when in fact there is). It is not a short in the key/post connection because I can wiggle the key all around while I am riding and it wont shut off... so I am thinking that it is internal wiring or computer.
I Bought this 97 GTX 3 years ago. Seller said it had a problem with the lanyard post and that a local dealer told him to replace the post and the problem would go away.
Well it didnt. New Post same problem.
Has anyone else had this problem fixed? if so, How?
I read somewhere about testing the resistance across some of the wires to make sure that it is in spec, but I dont know what to test and what the spec is. The puzzling part is that it is random.
Thanks for any help.
