bronco_remy
Hello all, first post for a complete PWC noob. Just bought the 97 GTX.
It started and ran when I looked at it, won't start now.
It turns over strong.
I get spark at both plugs and the plugs are gapped properly and new. When I had the plugs out I turned the motor over while I had a clean rag over the plug port and I got compression and the rag stayed pretty clean (no oily sludge that I was dreading)
I've read about the gray fuel lines. The previous owner replaced all of them with automotive black. I have not taken the carbs off, but I did get down to where I can see them. When I press the accelerator I do not hear the hiss of the fuel coming into the carb that I expected to (I am thinking of my old quadra-junk four barrel that made a heck of a hiss when you pulled on the accelerator linkage and listened for the fuel) First question, should I hear the tell-tale fuel hiss in the carbs when I press the accelerator?
Second question, every so often the beast gives a little pop or mini-backfire out of the back and it spits some water out. Where is that water coming from? The big white barrel looking muffler, I would guess. I cannot help but feeling dread at seeing that happen.
Any other ideas would be appreciated. Hoping I did not buy a lemon......
This is a great forum.
Bronco_remy
Bronco_remy
