Hi all,
I just joined, hoping to get some Sea-doo advice. My cousin picked up a gently used 1997 GTX last year. When he launched it in the spring, he left out the drain plugs, and a few weeks later found it in the basement story of the boat house.
He removed the plugs and cranked out some of the water. 6 months later, I have a Sea-doo in my shop with a seized engine.... I wonder how that happened?
Long story short, I filled the engine with diesel and left it for a few days. With some light pressure on the crankshaft I was able to get things moving. However, the engine is now hydro locked. I have cranked the engine to remove all of the diesel from the top end, and I also removed the drain plug on the rear left side of the engine. If I put even one spark plug in, it won't crank. Only once did it turn over with the plugs in, and a large volume of water blew out of the exhaust hole.
I removed the boot between the muffler and the exhaust pipe, nothing came out. Is there somewhere else I can try and drain from? My concern is that since it's diesel, it won't just evaporate like gas would. I guess there is also a chance there is water sitting somewhere in the exhaust from the sinking... just a thought.
Would appreciate any advice.
Thank
Thank
