Check the cable to the oil pump, make sure it aint stuck, or arm stuck open.
you can go premix, block off the line, that goes to the pump, or install blockoff plate, but you still need the oil to the crankcase, keeping the lines from the resivoir, or bypassing the resivoir using those same two lines, tied together, but use injector oil only for the casing...
