'97 GTX gasket leaks - Help please
brewseadog
See the pic. Can you tell me if these leaks are a major problem? If so, what steps do I need to rectify them? I do plan on replacing the grey hoses and clean/rebuild the carbs this fall.
Thanks.
Bellows.....
You'll need to remove the RAVE valves and see which one is leaking. Check the bellows under the cap. You may have a retainer spring that let go. But the black oil is from the RAVE valves............:cheers:
