SLIMCAT
Hello to all
Started the gray fuel line replacement process. I was going to remove and clean the selector valve assy. Is this accomplished by removing the phillips screw under the black plug on the selector knob? I have tried this but it seems really tight while turning.
Also, i hadnt planned on doing a full carb re-build, just all the filters and lines, do the carbs need to be removed to access the filters? Are there gaskets between the carbs and block?
Thanks fellas,
Slim
Thanks fellas,
Slim
