Let me start by saying I am thinking about selling this so I need some convincing that it’s going to be ok lol.
97 gtx, new stator, new ignition coil, new stator connector. New top end, new rectifier rebuilt carbs. Cleaned RAVE valves. Premix with oil supply going to rotary valve.
1st thing: i have a 1/4 tank left in the first tank since rebuild. Break in period. Running 32:1 oil. Not holding it down a lot, all over the throttle now. Feels slow and only hits 40 when on it a little bit. Should be faster ? 135 compression in both cylinders. Also to note: the cylinders were not honed, but no gouges, smooth like a baby
2nd thing: it’s taking on water, enough that it shouldn’t be ran too long. It’s only when running. I checked a bunch of lines. Ran it through the hose and still can’t find it. Any common areas i should look for? I don’t think it is coming out of the metal flange on the exhaust. I also tightened the line that comes off in a T on the bottom of the cylinder.
Any insight is appreciated. I want to keep this but it isn’t not running fast enough.
