Long story short my dad bought 2 skis from his neighbor. The 97 gtx ran fine with a rebuilt engine, then started to do random no turn overs. Hit start button, nothing. No click, no noise nothing. Then all all of a sudden it would work fine. Put them away for the Florida winter. April I went over, to get all 3 skis running.2 start and run fine. 97 started its intermittent start again. New button and starter problem still existed. Traced all the wires, 12 volts to the mpem, only 4.5 to the start circuit. Called around and verified mpem was dead. Should be 12 volts all the way around from what I was told by 2 different dealers. Order new after market, it comes in, put it in,go to program the ignition number, and find the warning horn is bad. dc it, put a c cell battery to it, nothing. Replaced that. Still no beep or noise when I insert dess key or try to program the mpem. Test it with a c cell again and it works fine. use a different speaker and could faintly hear noises. Program the mpem. Now the starter solenoid just clicks multiple times. Trace all of the wires, replace the deutche connector, follow the power all the way back to the mpem, and sure enough 12 volts to the mpem, only 4.5 out to the starting circuit. So hears my 2 questions as the dealer is going to warranty the new mpem. and I don't want to kill a 2nd new one.
1.What will kill an mpem with out even being in the water, and never even starting the engine.
2. On the same note, the ski will kill a battery really quick if it sits more then 24 hours with out disconnecting the battery. Brand new battery out of the box with a top off charge. Just tracking the voltage the other day the battery went from 12.56 to 11.8 in the space of maybe 3 hours. Any ideas on that? My gut says the 2 are related, but I cant think of anything that would not only short an mpem out, but kill a battery. Any yes, I did get a nice little spark when I connect the power cable, but not since I traced and cleaned all of the connections.
