ground minnow
I would first like to thank all the members on here, you have helped me so much up to this point!
Long post (sorry) but I need opinions. I bought a '97 GTI and it hadn't ran in 4-5 years. It takes a while to start but after it starts it runs great up to about half throttle. After that it starts sputtering and if I back it off to around half throttle or a little less it will run clean for as long as you want to run it. The compression on the mag side is 143 and PTO side is 140
The following is what I've done up to this point.
replace the oil lines on the automatic oiler Replaced the old gas lines
Replaced solenoid
Replaced coil (Amazon) this purchase was made before I found this site and realized there are quality part dealers out there
Replaced MPEM (Amazon) this purchase was made before I found this site and the reason for replacement was somebody stupid hooked positive and negative cables up backwards. It's me, I'm stupid
Rebuild carb (genuine mikuni) OSD back to stock
After the carb rebuild it held 10 psi for 45 minutes and the pop off was at 35 psi. It has stock jetting and LS and HS were 1turn and 1-1/2 turn. I made sure to follow the rebuild thread to the T and made sure all passages were open. Also the dental floss technique worked perfect for me. I have also tried running it by bypassing the on/off/reserve and hooking straight to the pickup on the reserve nipple.
I have check the voltage and it never gets above 14.2 volts. After running it for a few minutes I noticed that the top 5amp fuse was almost melted into the MPEM. I was able to free it up and it wasn't blown but it did replace it and put a little dielectric grease on it.
Also it has never beeped when the key is installed until today and it beeped twice and then fired up really quick. I rushed it to the lake to try it and in a 5 minute trip no beep when I got there and was a bear to get to crank.
Any help would be GREATLY appreciated.... Thank you so much for even reading this long post!
Replaced solenoid
