Pulse Line connected?
Bypass the selector for now, this will answer if it is the issue. It likely does need replaced, but I'd still bypass it for now to test the system.
You can pressure test the lines and see if they hold pressure. If not, you are sucking air. Or, do a vacuum test on them, probably easier to do that.
