Advanced diagnostic.....
Charles, by pushing the start stop button 5 times, your putting it into diagnostic mode. You said it beeped. How many times.
I see you did two test to your post. There are 4. I'll go and look now, then come back and re-edit.
When I had this problem, my DESS lanyard was fine. It was the post. I'll be back to edit shortly..........
I'm still looking in the manual for the test of your year model on the post, but coming up empty handed. Some years of the manauls seem to have more info than other years. I'm going to post the test for a newer model ski below. If your post has the same number of wires with the same color, this test may be applicable to your Doo too. Please let me know your results and let me look around a bit more for info.
If you get a good deal for the dealer to test it for you, that's great. But if they too determine it's your post, they'll charge you for the post + a minimum 10% intereset on the sale, then about $90 bucks an hour for labor. This part is easy to trouble shoot and repair yourself. I'm really leaning on this post because of the same problem I had with mine.
The cap has a ROM chip in it as security to communicate with the MPEM but the post has a magnet in it for contact with that chip. Over the years, the magnets field of energy weakens.
Do this test and let me know what you come up with.........
Test 1: with the cap off, put the tester wires on the black wire and the black/yellow wire. The circuit should show "open" at 68*F.
Test 2: with the cap off, put the tester wires on the grey to the post terminal (the little metal button on top of the post). The circuit should show a reading close to 0.
Test 3: with the cap off, put the tester wires on the black wire to the post ring (the little metal ring around the post). The circuit should show a reading close to 0.
Test 4: with the key ON the post, put the tester wires on the black wire and the black/yellow wire. The circuit should show a reading close to 0.
