Hello Everyone,
I have a 97 GTI with 717 Rotax 2T engine.
Initially when I start it takes 3-5 seconds pushing the starter. When it's hot, it takes just 1-2 rotations... within 0.5 seconds.
But yesterday I flipped it upside-down. Then I did the clockwize rotation to flip it back up. But since then - I cannot start it. I rotated the starter a lot without plugs. (Also there are sparks from the cables when I try) I cleaned the plugs many times. (I tried: dirty vs clean plugs - dirty plugs do not make sparks.) When I put them back, it tries to start - I hear 1-2 real ignitions within .5 seconds, then back to just starter rotating the engine... I remove the plugs - they're dirty (oil, gas and maybe water), clean again, put them and the same thing happens again. I did it 10+ times, but it cannot start.
I had a similar problem when I water-flushed without starting the engine, after 2 days and a lot of spark plugs cleaning and trying (with similar results)... finally it started.
I think in the cylinder there are remains of water. Yesterday I tried to put a lot of clean petrol inside from the spark plug holes. Then I rotated without plugs 30 seconds, then the same clean/put/try procedure, but without success.
Now I left it without spark plugs to rest (and mybe dry). I hope next time it will start. Any idea what could be the cause? Am I on the right path? How can I make it start after such thing if it happens in the sea if I'm far away and alone with nobody to pull me back? (I have spare plugs, but with such results, if it gets wet - I have no solution to start it even out of the water.)
