GSX Newbie
I bought a 97 gsx that wouldn't crank Engine was clean and looked good from outside. I got it back to my shop and found water in rear electrical box. I cleaned out water and rust then tested with new battery. Will crank when jumpung starter and had no spark so replaced starter solinoid and CDI. Now it cranks and has spark. It sat for 3 years, so i drained the fuel and oil there was no fuel in filter so I just hoped there was no fuel in carbs. I put new hi test in tank after putting carb cleaner through lines and cranking. I get fuel to engine but won't start.
The original issue for the prior owner was it was running fine on his last use then next time went to water cranked and no start just like I have now.
It does have the grey lines and the high temp light is flashing on dash. Would a bad temp sending unit prevent it from starting if it thinks it is hot?
